When I charge my maxx overnight and then turn on in the morning, it shows the battery at 100%. Once the phone is on for about 20 minutes, the battery drops to 94%. Is this normal? what can be done to fix?
I noticed this as well but then when I shut the screen off after a few minutes I would turn the screen back on land the battery was at 100%. Weird but it does it all the time.
Actually the phone charges after it says 100%. Check out the circle widget it will say 100% and still have the charge icon till it fully charges.
The phone stops charging at 100% but doesn't show a discharge while plugged in. This is true for every phone but you're noticing it more here because you don't expect to see a discharge happen so quickly. Do you use Wireless Qi or the standard wired charger? I find the Qi to be more likely to do this and it even shows in GSAM as off the charger since it stopped for a bit.
I have never seen this before.
Sent from my Motorola Droid Maxx using Tapatalk 4
Eh, don't worry about it. I remember back in the Droid RAZR Maxx days we were always wondering why the first 10% faded quickly while the rest felt like a trickle. It sounds as if you're trying to find fault and you're digging deep. Its natural but calm down and enjoy the phone. You're seeing better battery then a lot of others here to be honest.I'm using the standard plug In charger.
Sent from my XT1080 using AC Forums mobile app
I bought a Droid Maxx and received it on Saturday. I charged it last night and used 4G for about 15 minutes and then shut it off. After texting some people (without WiFi or 4G), I noticed my battery life fell to 46%. I called Verizon (my carrier) and they told me that if I do not let it fully charge the very first day at 100 % before playing with it, the battery will not retain 100%. WHAT??? If it was true, then they should put a disclaimer on the phone and say "Do Not use until fully charged". Sounds like BS to me but they are offering another new phone to replace my already new phone (since I have 3 days left to decide). Any suggestions? I'm disappointed.
