Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Like Tree1Likes
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Default AOKP/AOSP questions? I am going in!
    Soooo...I slept all day for some reason and just got done my other job.
    I have three rezounds in front of me that I can keep for the next 2 days or so. I am also really bored and haven't flashed in awhile.
    I am going to take one of them right now and flash some AOKP goodness on it to see what all the fuss is about.
    Anyone have any questions for when I am done?
    EDIT: I will not be able to really tell you about battery life, I wont have them long enough
    Thanked by:
  2. #2
    skatergirl's Avatar
    Lovin' My Phone
    Posts
    Default Re: AOKP/AOSP questions? I am going in!
    Quote Originally Posted by piizzadude View Post
    What is AOKP?
    ~Janet~
  3. #3
    twolastnames's Avatar
    Posts
    ROM
    To embarrassed to say
    Quote Originally Posted by skatergirl View Post
    What is AOKP?
    Android Open Kang Project.
    Kang is stealing in nerd terms.
    Pizza, I'm joining you as well. My question. In terms of Smart phones OS's, and movie computers, which one is Viki, the iRobot computer, which one is skynet, and is Windows phone Johnny 5?
    What do you give Akop? A doughnut.....
    Thanked by:
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Android Open Kang Project....
    It is AOSP (android open source project ((Pure android))
    A decent definition of what it is:
    Thanked by:
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Quote Originally Posted by twolastnames View Post
    Tough one
    I would say skynet is Android...it is out in the open, free and starting to permeate all of our lives
    By default that makes iOS the iRobot computer
    viki is palm
    I would give you windows as johnny 5, advanced but not there
    Blackberry is B.O.B:
    HES likes this.
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    I installed AOKP over Venom without a hitch. The dev says that you should use TWRP, but it went fine with amon ra. LISTEN TO THE DEV. I am using a phone I could care less about....
    The SD card definitely doesnt work, but there is a fix already, it just hasnt been updated.
    I forgot to load gapps....
  7. #7
    Posts
    ROM
    Did you DL the 20120429 gapps? I almost forgot about this. It's been so long since I flashed anything other than sense stuff.
  8. Thread Author  Thread Author    #8
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    i am working on the 726 apps but the DL is slow
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Here is a tip: do not try and change your network mode. If you pull it up, it will not have either chosen, if you choose cdma/lte, you will lose 4G...
    Tip 2: wifi does work...you need to turn it on, reboot and then you will be fine
    Tip 3: dont forget the gapps....its a pain if you do
    Tip 4: use the 20120429 gapps, it does not like the newest (JB) apps. or at least mine doesn't. Keep getting a play store error
  10. #10
    Zruben016's Avatar
    Posts
    ROM
    EuroSkank/ Franco r230
    So this is kind of a mid level stability ROM?
  11. Thread Author  Thread Author    #11
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    yeah. The RIL was only cracked a few days ago so there is still a ton of kinks to be worked out. I am kinda positive that until ICS kernel source comes out it will have flaws.
    I have to say, if you like 3g and do not need a camera or bluetooth, it is kinda nice...and I havent scratched the surface yet
    Thanked by:
  12. #12
    Posts
    ROM
    Once the SD card thing is fixed, I'm in like Flint on this. The camera not working is no big deal to me, but I do have an assload of music I listen to quite regular.
    It's hard to explain to people how much smoother this is than Sense, and it's only a Beta, at best. It's not the screen transitions, but when you hit the home button, the phone just goes there without hesitating. Plus I already use my own apps and widgets, so I don't care to much about the Sense ones, even though there are parts of Sense4 I really like.
  13. #13
    Zruben016's Avatar
    Posts
    ROM
    Ah, that makes sense. Maybe I'll wait to flash until they get a couple of nightlies out and hopefully then some of those kinks will be out. Don't want my girlfriend to get too mad at me for flashing every other day. hahaha
  14. Thread Author  Thread Author    #14
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    lol....i would wait as well, but I have extra rezounds laying about and why not experiment while I have them right?
  15. Thread Author  Thread Author    #15
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    I am going to wait for totally stable 4G and the camera before thinking of this as a daily driver....I am going to say that this thing flies
  16. #16
    Posts
    ROM
    I'm gonna use it all day at work tomorrow, see how it goes. That will give me 3 hours of internet usage to see what happens.
    Flies is an understatement, it's pretty quite an amazing difference. What is gonna happen with the Voodoo Google baked into JB to try to predict what your gonna touch to speed up the UI? Makes me wish for the ICS upgrade so we can get source code released to make these things happen easier for the smart people involved.
  17. Thread Author  Thread Author    #17
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    I am going to do the same. I will carry the AOKP one and my "good" one just in case but try to stick to the AOKP.
    Yeah I said that in my rezound isnt dead thread that I want ICS more than ever now, jsut for the source....
  18. #18
    If you use boot manager to install you can use your SD card. I can use all my files, music, and even my tb backups.Strange thing is its seeing my internal and external SD as one. I have like 30 gb under storage in settings. But it flies
  19. #19
    NoYankees44's Avatar
    Posts
    ROM
    Viper
    Default
    So is there anything besides Bluetooth and camera that does not work basic function wise? I know you said it is fast, but is it smooth yet? Does it still have the on screen buttons?
    Keep us updated on battery
    Sent from my ADR6425LVW
    Htc Rezound(s-off on ViperRez) ---- Asus Tf300(unlocked on CROMI)
  20. Thread Author  Thread Author    #20
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    it is very smooth, almost no stutter from my experience so far. You have the option to use the on screen buttons or not.
    There are a few little annoying things that I have found but as far as major bugs, I would say no
  21. #21
    Posts
    ROM
    no stuttering on my end today. The screen off battery life is crazy so far. 3 hours dropped it only 2% Mine just caught the roaming glitch, and the flashlight does not work. But my alarm went off this morning, and my phone has yet to catch on fire, so I'm plenty happy.
  22. #22
    SirKnightDavid's Avatar
    Posts
    ROM
    viperReZ 1.0.3
    Interesting! I didn't know that AOKP was coming to the Rez. I played with a a few builds of AOKP on my old Dinc, but they stopped supporting the Dinc and I switched to Cyanogen.
    I may have to give it another go on my Rez once it's a bit more stable, though I gotta say I'm really loving the Viper ROM so far.
  23. #23
    Default
    Other than the known bugs such as camera and sketchy Wi-Fi I haven't had a single issue on aokp. Running it for over a day now
    sent from my rezound running AOKP
  24. #24
    Posts
    ROM
    Viper
    Default
    Why do they say to use twrp? Is there a safety issue? Would it be a good perminant replacement for amon ra?
  25. Thread Author  Thread Author    #25
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Default
    Not sure why they say that, but the dev is saying it is the one supported. I have had no issues with ra round anything...backed up viper ,flashed aokp, messed up and restored viper, reloaded aokp with no issue.
    Sent from my PG86100 using Android Central Forums
