ryanjma
Active member
Is anyone actually planning on getting both devices to use at the same time? Not sure if people have stick to one phone for work and one phone for personal use.
gonna go for the black one should i get screen protector and case for it?
Mexican music plays
I think the default is the Samsung Keyboard but you can also use Swype or install your own keyboard with an appIs the Google keyboard available as the default on the note 3? It's the only one I like to use on my nexus
Sent from my Nexus 4 using Tapatalk
2 points:- Fact of being able to remove the battery - doesn't really bother me much. If I ever will think of carrying an extra item (battery) with me, I will rather carry a powerbank instead.
Guys,
I have been thinking about the same thing for a couple of weeks now, following every news about the N5 prospective release, leaks, etc. I was veeeeeeeeeery close to purchase a Note3 last week, but then decided to wait until the N5 would be released. And here are my thoughts I would like to share with you that will (hopefully) help me to make a correct decision (just my opinion, feel free to disagree):
If you have doubts about the software (vanilla Kit-Kat VS TouchWiz+Stylus):
As many said, both devices provide different experience software-wise. People like me who never had a Note are wondering "Is S-Pen really that useful?", "What if I'm gonna hate TouchWiz?", etc. Well, worry not, the solution is simple: If you purchase a Note3 and then at any point will decide that "TouchWiz+Stylus = gimmick" and "Gimme my vanilla android back!" - just flash a custom ROM, I'm sure there's gonna be plenty of them. As a result you will get a super-flagship with vanilla Android and a barely working S-Pen, but who cares about the latter?
==> if your worries are mostly caused by Software, get a Note3. I personally do not see any issues as I will be installing my own ROMs/launchers/keyboards on any of them anyway.
If you have doubts about the hardware (removable battery, SD-slot, 3Gb RAM, 3200 mAh battery in N3, etc):
- RAM should not be an issue. 2Gb on a stock Android is mooooore than enough.
- SD-slot isn't really THAT advantageous if you have a 32Gb N5 (but if 32Gb is still not enough for you - read no further, just get a Note3)
- Optical Image Stabilization (but just 8 MPix) camera on N5 VS 12 MPix and no OIS in Note3: There's no difference for me. It's a phone. It takes decent photos. When I want GOOD photos I carry my DSLR with me (yes, it is bulky, expensive, heavy and I love it!).
- screen size: if you absolutely "don't like phablets" or vice versa "want nothing less than 6"", then why are you still reading this? This being said, let's assume you're like me - will like both 5" and 6" screen, as long as it's FullHD.
==> for me personally these devices are quite similar hardware-wise, meaning that I will not regret about anything if I get either of them, except for just one last thing
Battery capacity: now THIS is the most important factor of all, which is why I'd like to look at it separately.
- Both devices have Snap800 processors clocked at same(ish) speeds
- Screens will have same FullHD resolution
- N5 will have a 5" and Note3 has a 6" display
- N5 will have an IPS and Note3 has %AMOLED display (or whatever it is called now).
- N5 will have Android 4.4 KitKat which will be more battery-friendly
- forget about "power saving modes". Let's assume we will actually USE both phones.
- Note3 has 3200mAh battery which is 40% more capacity than in a 2300 mAh rumored in N5.
- **** N5 32Gb version is rumored (!) to appear with a bigger battery (3000 mAh)
Will a 40% less battery capacity (N5) be able to provide same battery life as on a Note3? I very much doubt it. Even if we assume that Google will do a very nice job optimizing the battery life in KitKat, even if a 20% smaller screen (still with with same resolution) will drain less juice, even if IPS will be much more battery-friendly than %AMOLED - I still think that Note3 will beat N5 on the battery life. Big time.
==> get a Note3
But.
If the rumors about the 3000 mAh battery in a 32Gb N5 version are true, then N5 will kick Note3's ar$e on battery life, easily. Let's just hope that a larger battery won't make the device twice as thick...
if (3000mAh) and not (much_thicker) then begin
buy(N5);
sorry(Note3);
end else begin
buy(Note3);
shut.up;
end;
I honestly think I would trade my Note 3 if I had any hope for the Nexus 5 coming to Verizon. I miss stock Android. There's nothing better than a Nexus experience to me.
Sent from my Verizon Note 3 using Tapatalk
