I don't play games on my note 3 Except, Solitaire 3D Pro.
This game has a configuration called 'Animation Speed'. It also works extremely well with the Stylus.
I set the 'Animation Speed' to the fastest. On the Note 3 it is lightning fast. I enjoyed playing as fast as I could move the Stylus.
As I play The Note 3 becomes very hot around the camera lens on the back.
After a long while I decided that the heat was a problem. I don't have a heat problem with any other applications. I decided to reduce the animation speed to half.
As you can guess the heat problem evaporated.
In past years programs sometimes had a problem called 'thrashing the disk'. I suspect that I was 'thrashing the processor'.
Nothing wrong with the application, it is good. Problem was just me.
Sent from my SM-N900V using AC Forums mobile app
