has anyone bought a extended battery that fits without an new back door? which one?
also if you use the fast charge with it will it charge quick or blow up lol
If you charge a lithium battery at faster than 1C (IOW, if it's a 7,000 mAh [7 AmpHour] battery and you charge it at more than 7,000 mA), you'll make sure it has a short life. (Which is why a 5 minute full charge may be great marketing, but it's lousy engineering.) Charging a lithium battery too fast can cause it to explode (from gas pressure build-up) or catch fire (from overheating).
I prefer carrying a spare battery or two, and have a charger to charge them outside the phone. They charge at the normal rate, I can swap batteries at 40-50% (which gives the longest life) and it's cheap. (For most phones, 2 good batteries and a charger run around $25.)
I saw a 4500 mAh battery on eBay that claims to be the same size as ours. Anybody ever try it it's only $7 so I'm worried if it's any good
If you haven't seen an extended battery that fits within the original case - you'll have to get out more. By "extended" I mean a higher mah level than stock which is 3220. I used a 4200 mah on my N2 to great advantage. I now own 2 extended batteries one rated at 4500. I am trying to avoid those thick heavy batteries as good as they are. Unless you're going on a long expedition with no access to electric, or solar power I don't see a widespread need for 10,000 mah. Those within the case extended batteries are widely available on Amazon and EBay , although I've had some bad experiences with vendors from our friends in China.Haven't seen an extended battery that fits inside the original case yet. I ordered ZeroLemon » Zerolemon Samsung Galaxy Note 4 10000mah Extended Battery + NFC + Rugged Black Zero Shock Hybrid Protection Case – Black for myself based on past experience with S3 and S5 kits from them. They include a quality case with the battery, BUT be warned that the phone will be nearly 21mm thick with this setup and as such is not for everybody. Full NFC support for S-Beam, Google Wallet, etc.
