A
AC Question
Samsung Note 4 on Wind Mobile - Incoming Calls Going to Voicemail
I have a Samsung Galaxy Note 4 on Wind Network and the problem is that the while the phone shows full strength, the calls straight away go to the Voice Mail.
So far, I have done the following but no effect :
a) Check the Block or Call Rejection settings and everything looks fine.
b) Gone to the Idle Mode and Switched off Idle Mode.
c) Factory Reset the Phone, Disabled All Apps
Still the same problem.
Can anyone advise if they have the same problems and do they have any suggestions.
P.S - Wind Mobile has asked me to take the phone to the Warranty Centre but I not sure if this is a phone problem.
