Techno-guy
Illusion.
Both 1920x1080 and 2560x1440 creates a 16:9 aspect ratio when viewed in landscape orientation.
Not exactly an illusion. The 'trick' here is that Samsung's screen wraps around the sides so it's a way more efficient use of space. The iPhone screen (on the flat part) is considerably wider than the S7 edge because a portion of the edge's screen sits on either side of the device and the iPhone then has a bezel around the screen (which the edge does not on either side).
