S7 Edge is have a big screen issue under the sunlight. How can I fix it?
designerge30
10
s7 edge have big screen issue under sunlight
guys i am really disappointed i buy a new s6 edge+ with original clear case and i get shucked that the original case scratch my screen i try to keep it with me then i feel too bad i sale it after one month using, then i buy a now s7 edge now i face the same thing happened with all of you i can see some lines and in some places something like spots all appear under sunlight with white screen only, i feel bad i don't now what to do i just can't ignore it lool every time i remember it i feel too bad :':)':)':)':)':)'(
brava27
236
4
18
Re: s7 edge have big screen issue under sunlight
Go home. You're drunk
Creshosk
