I like the Google apps so, for me, it's not a big deal that they are there. I really love vanilla Android. I just think that when you spend $1000 on a phone you should be able to add or remove whatever apps you want as long as they aren't essential to the CORE OS. That's all...
And that is what you got.
Nothing else but a camera.
Not enough of a Hard drive. Not enough of memory.
NO Sd card. No storage.
Small battery.
Most important things on the phone.
Look back to when the Iphone was made.
They had 16Gb storage.
When you needed to do a software update, YOu had to delete a lot of picture and things off you phone to be able to do the update.
Then Samung came out with the 32 gb phones. Now you didn't have to delete things off your phone to do a update.
They samsung came out with the 1st 64 gb phone and a Sd card.
Then samsung came out with a removable battery.
That was super great. You could carry different batteries with you.
Batteries was cheap.
Then you got people that wanted a phone to be like a Diamond ring on your finger.
So samsung left plastic phones that I likes and went to glass and made them waterproof.
But they break very easily.
And you can't change batteries with out having some body to take a heat gun and take them apart and replace things.
Then you lost your water proofing.
I'd like to go back to like the Samsung S5 style.
With the bigger batteries, more storage. SD cards.
Forget the waterproofing.
Quit dropping the phones.
I hate the bigger cases like otterbox.
They are too big and bulky.
What a phone cost has nothing to do with what you want to be able to do.
It has to do with HDw. And software.
Mfg makes the phones to their specs. Not yours.
