x893
I used the default browser to download the file from XDA. I'm not sure where the file was saved, but I used Astro File Manager to locate the file. I moved it over to the following location: phone>storage>SD card. Is that the right place?
That could be. ... but the galaxy s3 has an sd card as it's storage too. If you go into app drawer and open up my files..... Then select all.... the first listed is the phone. ... the second is your external sd card. ... you want the file there in the second listing. So you could manually move it there.
I don't use astro so not familiar with how it's "naming" each one. ...
But if you look around in "my files" you should see what I'm referring to and can probably find the file easily.
The first time I tried ....I used stock browser and then moved the file. For some reason the update didn't take.
Then I did what I previously posted and it worked no problem. .... I'm guessing the copying if the file caused an issue.
If you don't want to do all that. .... open up stock browser. ... hit menu button (next to home at bottom of phone).... scroll down to settings. .... Then advanced..... Then "default storage"..... change to sd card and redownload the zip file.
If you do that. .... Then you can just start the update procedure. .... Just remember the name if the file. ..... it'll be obvious cuz it will be the longest one in the list to chose from once you are in the update menu. ..... but you'll see. ....
