4300 mah extended battery s3
Dondie Handoy
I just bought an extended battery for my galaxy s3. Its 4300 mAh but when I check it using the Application du battery it only says 2100 mAh..how could that be? Am I cheated or there's something wrong with the application..I tried some several battery apps but it has the same results..can someone help?
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Welcome to the forums!
Is the physical size different? I would have though it would be. Other than that, short of actually timing your two batteries and which one lasts longer, I think you may have been cheated.
Where did you get it from?
Abdul Ali
