I'm just reading, is the lettering in blue? If so, that is stock recovery, you do not have CWM or it would
be orange and have additional choices.
You need to go back to start and try again. I did not use these files, I used the long way, it was easy looking back, but so many little things to do that can cause it not to work. For example, I kept using the computer command prompt, not knowing to right click in Platform Tools - wheh
"using volume up and down choose the unlock option"
I don't have that option. All I have are:
Reboot Bootloader
Reboot
Recovery
Power Off
Any ideas?
once your unlocked running the script again will just error at the unlock part, so no harm done
Works perfectly.. Finally got the balls to root my phone.. Very easy and I regret not rooting earlier! Thanks..
ok so its not a true one click but its pretty close, will walk you thru the whole thing
https://psp-1.com/
Update fully working
big shoutout to Austineasleyinfo for continued patience and testing
yes there are, download it to your computer and extract the zip
Will this work on a Mac?
You sir rock.no the phone needs to be on. and yes it will work for the nexus s
