Tysonsaurus
I found that the volume for the navigation is controlled using the phone side buttons, specifically "media" volume.
I'll have to look into that.
Does Waze work with AndroidAuto yet?
The new version of AA seems to be showing letters and numbers across the AA display for some users, including myself. Does anyone know anything about this?
Pocket Casts worksHas anyone found any podcast apps that will work within Android Auto?
Yeah, I'm seeing the same thing. Don't know how that one got past QA. Nothing I've tried has fixed it. I'm going to have to go back to an older APK until they fix it. It's unusable this way. Too hard to see the interface.
Long time lurker, first time poster. I love these forums and can almost always find the answer I am looking for.
I am at my wits end with Android Auto, Pioneer NEX, OnePlus, and/or Cyanogenmod 12s. See, I am not really sure which one of these are the issue. I get anywhere between 30 seconds to five glorious minutes of Android Auto use. After an undetermined, short amount of time my Android Auto freezes (navigation stops, audio stops, it all stops.) The only way I have found to remedy the situation after freezing is to disconnect and reconnect my phone. I then get another 30 seconds to 5 minutes before it freezes again.
Here is what I am running:
Phone: OnePlus One with Cyanogenmod 12s (Lollipop)
Unit: Pioneer NEX 7100 (Firmware 1.03)
Streaming Service: Google Play
Carrier: AT&T 4G LTE
I have even gone as far as trying a higher quality USB cable running from the back of the unit since i saw it suggested in the ONePlus Forums. I don't know what else to try at this point. The frustrating part is after spending quite a bit of time googling I have come up short of other people having this issue. I want to love Android Auto. It's the primary reason I purchased this unit. Any and all advice/help would be greatly appreciated.
Very much sounds like something's timing out on the phone at that point. Wouldn't happen to have another Lollipop device around to test with?
Make sure your USB cable is not too long. I found that if the cable is longer then 6Ft. It will start then close, or not start AA at all...
