battery dieing to quick..
giggalz41
Active member
Mar 27, 2010
32
i've rooted my phone a while ago and had no problems with quick battery drain...it started this yesterday i unplug it from charging..and an hour later i've got one bar left..its done the same today...how do i fix this?
giggalz41
Active member
Mar 27, 2010
32
i should mention that theres been no incoming or outgoing texts..no calls made or recieved..and status light for incoming mail has been turned off..its just sitting there untouched...
doogald
Trusted Member
Jan 3, 2010
4,425
55
Try fully charging. While it is plugged in, restart in Recovery. Go to the Wipe menu, then Wipe battery stats. Restart the phone; unplug as soon as you see the ROM's splash screen. Leave it unplugged until it is as close to drained as possible.
Let's see if the battery stats were bad or something.
livewiremaxx
Active member
Apr 26, 2010
41
I have a similar problem. very little uses and walla battery bout dead. Ive thought about getting an extended battery but then I wouldnt be ab le to use custom caes and such
