sok1109
I recently had the same problem with my Galaxy Note 4, and was ready to have it repaired. But, while cleaning the screen with a lens cleaner I also wiped the camera lens.......and INSTANT CURE. While previously I'd wiped the lens with only a damp cloth and it looked clean, apparently there was a film that confused the camera. Yes, water's great, but it won't remove an oily film. Hope this also works for you. Good luck - Dave
Omg *slaps forehead*... so simple. I just usually wiped it with a regular cloth. It worked! Thanks!
