First day with my 360. Few questions
Hi
Just got my 360 today and so far I'm really liking it and trying to get the hang of Android Wear. Apologies if these questions are simple fixes and such, but I can't figure them out.
1) With Ambient Mode enabled, is the screen supposed to stay on all the time? (in its dimmed, less frequently updated state). I have it enabled at the moment and all it seems to do is dim after a few seconds of inactivity and then will turn off completely if I don't move my wrist. It then wakes up again if I move my wrist.
2) Can I use the "Ok Google" command while the screen is off or dimmed? Voice commands only work for me when the screen is fully awake.
3) The watch frequently says "Offline" when trying to make some voice commands. Is there any way to make this more reliable? (Currently paired to a LG G3)
Thanks
Hi
Thanks
