Can I get some help with my Nexus 4?
A
AC Question
Nexus 4 help
i broke the digitizer on my nexus 4 back in June and tried countless times to get pics and vids off it. The phone hooked up to my wifi and i was thinking is there an app i can use to get the pics and vid off it by downloadin them to my pc usin wifi?? Its rooted but i didnt do the adb stuff cause i was to lazy the phone dont even connect to my pc after i updated the drivers either i tried uninstalling and installing the drivers back no luck either
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,620
4,763
113
Re: Nexus 4 help
Welcome to Android Central! You could try using Google Play Store on your computer browser to install AirDroid or Wifi File Explorer to the phone. Then use an OTG cable to connect a USB mouse to the phone to access it, and transfer the files wirelessly.
ukfred
