noticed some bugs/ glitches in my home screens recently..anyone seen their screens do similar things yet?
Wow. Reboot. If that doesnt help then you may need to do a factory reset. If your phone is rooted then I would suggest restoring with a backup. If you do not have a back up then use Odin to restore your phone.
That just about looks like a reason to tell Verizon you want a replacement. However the first thing they will do is a Factory Reset.
When was the last time you did a reboot?
I try to do a battery pull at least once every other week...
You might want to do it a little more often. While Android is good with multi-tasking and killing unused apps, you still need to let the phone refresh itself every so often. I would try every few days and just simply turning off and back on should be fine without a battery pull. Glad to see it was a simple fix!
I know people will argue that you dont need to do a battery pull on android devices. None the less it is still an electronic device powered by a lithium source.
Pull the battery. Then without the battery in there hold the power button down for a few seconds to release residual charge put the battery back in.
Yes. Draining the X of power also drains the residual memory and allows it to do some trouble-shooting as it powers up.
Re: landscaping home screen - does it happen when the X is in a dock or a magnet gets close to the corner where the menu button is located? If so, that's a dock mode and not a problem. Only works with the magnet involved, either from the dock station or from a random magnet that gets too close.
OMG... to think about it... my home screen goes into landscape mode when I sit my Droid X on my MacBook.. and I think there's magnet in my MacBook that switches it into car dock screen...
Actually thats been reported as shown below in bold on the motorola site
13. fixing screen orientation defaulting to landscape. The screen tend sto default to landscape when flat on a table or when it should be portrait
the motorola people said they was looking into it
hopefully motorola will give the Droid X the option to landscape in the home screens...
If you check out LauncherPro (free) in the market it might .I know LauncherPro Plus you can( Pro.ver. on my dx) , there is a link from the free version in the market to the Pro version . It's just the way that app dev. has to post it from where they live in the world.
