Yah, thought about that too...unfortunately both my Lowes and Home Depot don't carry it...SUCKS!
But thanks for the help...currently looking around town to see if I can snag some somewhere, was hoping to do the MOD this weekend so heres to either finding copper tape, using aluminum foil, or 26-30AWG wire (think that should be thin enough yet hold the current needed).
No that charger does not give out enough amperage. You will need the palm one.New here, been lurking around while looking for info regarding all this. Planning to do this to my GSM GNex soon, hope it works!
Quick question, some people were talking a lot about which chargers work/don't, which battery covers and so on. If I have the Pre Touchstone cover + dock, an extended battery door, and use my UK Samsung charger which came with the phone, would I be fine, or should I still order the Palm charger?
Thanks in advance for all your efforts, really appreciated!
Actually I was trying to hide the upside down palm logo with sandable primer and black paint but got impatient with the multiple sprays.
I don't think I'll plastidip any surfaces nor will I add any additional magnets. (I don't have either)
If I do find some magnets to put on, I'll make sure to follow your tips. Thanks for starting this thread!
Runningwarrior08
Yes, and yes(With a dremel and a steady hand using copper tape not wire)
Extended battery cover is what I have with mine, as for the car dock I couldn't say I don't use one. I use my touchstone. If you do that make sure you get the Palm car charger, only one that works.
I have had mine modded pretty much since the day this thread came out. Still works great
I just completed this last night without any issues, and it was charging on the touchstone, now this morning i get nothing, it will charge via the usb plug but wont charge on the touchstone anymore.. nothing has changed except the phone charged overnight via usb so the battery is full but shouldn't it still go to charging mode on the touchstone? nothing happens at all
nothing is shorted and it was just sitting on a table all night!
