[NOTE]This is a relatively simple process, being as I don't have a Evo 4G any longer things may be off a little bit because i cant test, so please feel free to correct anything that is wrong.[/NOTE]
Lets just jump right in!
[INFO]I'll have helpful links at the bottom for after youre done rooting[/INFO]
[WARN]DISCLAIMER: Myself nor revolutionary is responsible for what you do to you device, it is at your own risk.[/WARN]
1: Download and install HTC drivers
HTC drivers
2: Download the rooting tool/program revolutionary
Revolutionary, downloads are at the bottom of the page. You will need to enter in your Evo's serial number (under the battery) and be sure to save the beta key. You'll need it later.
3: Enable USB debugging (settings>applications>development>turn on USB debugging) and connect the evo to your PC as charge only
4: Un-zip the S-OFF tool and run the program, making sure to install the custom recovery when prompted. (unless you already know what you're doing and want to put Amon_Ra or TWRP recovery on there)
5: Download
SuperUser and boot into recovery. To enter recovery: power off completely, yes battery pull while off too be sure, then hold volume down+power and from there go to recovery and confirm.
6: install superuser from recovery
YOU ARE NOW ROOTED.
7: (optional but highly recommended) Make a nandroid backup via recovery and then put it on the PC just to be sure nothing will happen too it.
