I had the same issue described here. Using Sync 3.5.1 (4.29.12285) with a Samsung Galaxy SIII (Adroid 4.1.1), I received the error message "the currently selected phone does not support text messaging via bluetooth".
Here are the steps that I used to get it working...
1. Turn off Bluetooth on the S3
2. If the vehicle is on, wait for the phone to be disconnected from the vehicle
3. If not already on, turn on the vehicle ignition
4. Turn on Bluetooth on the S3
5. As soon as Sync is paired, the phone will have a security request that I only found by accessing the pull down menu
6. Pull down the menu on the S3 and it will indicate there is a Map Request, do you want to allow Sync access
7. Select the Enable checkbox to not be reminded again and press OK
8. To test it, dial *DATA# on your phone and wait for a text to arrive
9. When the text arrives, the vehicle will play an alert and indicate a message is available
10. Press OK to Listen
11. Voila!!!
The main issue is that the Map Request occurs when the phone is paired and you need to allow Sync permission to access the phone text messaging before the request disappears.
I hope this helps others.
