Gunslinger1981
Has anyone else notice a slowdown in the UI after unlock? My device does not seem nearly as smooth as it did before.
Need help... when i try to extract the fastboot.exe file to the tools folder, i am getting an "Access Denied" error.
any help please??
Are you trying to extract to C:\ ? If you don't have administrator privileges that could be an issue...try placing the zip in "My Documents" or something and try extracting there. If that doesn't work I don't know what the issue could be.
Anyone else do a face palm when they realized they forgot to enable usb debugging?
BTW, this is the driver that worked for me.
Dude you saved my life... I couldnt figure it out to save my life... If I were close to you it would be a beer on me.. I was about to throw my phone and laptop lol
For those getting the missing adpwinapi.dll error please read this SDK note:
"The adb tool has moved to platform-tools/
If you don't see this directory in your SDK,
launch the SDK and AVD Manager (execute the android tool)
and install "Android SDK Platform-tools"
Please also update your PATH environment variable to
include the platform-tools/ directory, so you can
execute adb from any location."
I did not bother to update the path, but 'fastboot oem unlock' was still successful....because the PATH update in the above instructions takes care of it.
I am finally unlocked as well. I wish there was a note on the first post stating that you could possibly see the boot animation loop for a few minutes. I bet I did it right the first or second time, but I hadn't read page 9 or 10 of this thread yet. Good luck to all!
Ok I am stuck. I ran the fastboot oem unlock, unlocked it and rebooted the phone. Now it keeps rebooting at the google screen. It showed unlocked but wouldnt go further. So I then locked it back, and its still stuck on google and reboots.
I did pull the battery too.
Help!
So after waiting, I put battery back in, went back into fastboot and unlocked again. this time it went past the google screen and went through the animation. Took a long time but eventually rebooted and showed unlocked still and then came up working. whew!
I got all the way to fastboot oem unlock and its just says "waiting for device' and never does anything else? Any ideas please?
The part in bold red, that's the part that I'm stuck on. I can't install the SDK Platform-tools. How exactly do I do that part? I've been trying for two full days now to get this ADB/SDK stuff set up properly but I'm stuck and it's frustrating. If it matters, I'm using Windows Vista.
Do you see a folder in the Android SDK directory that says Platform-Tools when you navigate to C:\Program Files (x86)\Android\android-sdk? If so, you've already done it. If not, you should be able to open the SDK and when it opens up, at the very top section of Packages, under the Tools section it will show that "Android SDK Platform-tools" is "not installed" and have a check box next to it. Make the the box is checked, and then press the "install packages" button on the bottom right.
Brandon
Okay, one last question. When I download fastboot.exe should I place that in tools/ or platform-tools/? The OP says to put it in tools/ but I wanted to double-check that part.
Platform-tools. The first post needs to be updated.
In fact, I think it's as simple as putting it in the folder where "ADB" is located. If you see ADB in the platform-tools folder of your C drive, put it there.
Brandon
