Looking for a specific battery widget
malhotra365
61
I'm looking for the widget that will display a battery w the percentage inside of it. I've seen it on a couple of screen shots and is usually displayed at the top next to the WiFi indicator. I tried the marketplace but I found like 50 of them.
AndroidOne
803
36
If you want to try a different approach download SysTray Monitor (by Creafire AG) from the market - free. This is not a battery widget though.
It will place a small sized percent label on the top bar's left corner. Very elegant, functional and with out using any screen real estate. Also keeps track of some additional memory stats for you.
MRBULLRED
168
I use this one.. works great..
pwnst_r
741
4
The problem with all of the battery widgets I've tried is that the icons are very low quality and look like crap compared to the other icons I use. This actually holds true for most apps in the marketplace.
techiechick
74
6
Have you tried PowerTime?
I know it's a paid widget, but it looks great. Also displays percentage as well as time remaining. Love it!!
See it on AppBrain here: PowerTime
ukfred
