Daniel.Lynch
Screen shots?
I'll upload some in a little. I'm going through a drawn out process to get the GPS lock to work properly. They will be up tonight!
Screen shots?
^^^^^^^ To add to that, PAC also uses the majority of the features from Paranoid Android, which means you get the hybrid settings, per app dpi and layout, and per app custom colors. I would post screen shots of mine but tapatalk won't let me.
Nvm, found it. http://img.tapatalk.com/d/13/06/11/yvuzygys.jpg
http://img.tapatalk.com/d/13/06/11/ureresuj.jpg
This ROM is so good. Can't believe ait until they fully implement Halo
I considered hakata, but im not rooted so I didn't know if i would be able to flash it.
Sent from my HTC6435LVW using AC Forums mobile app
There are two ways. If you got it to where you like it but still had those extra buttons, go to Settings>Hybrid Properties>Interface and then drag the slider for the nav bar to 0%, it should be under the DPI slider.I saw paranoid android, and I liked it but I couldn't figure out how to make it work without the extra home, recent apps, and back buttons. How do I remove those?
Alternatively, you can bring up multitasking screen, long press on the app you want to change, select hybrid properties, and then change it from there.
Hope this helps!
Yeah, with the red accents I could understand where you're coming from. Im personally a fan of this color blue. So when I saw they implemented it into sense five I got excited. Lol. Not sure if it's ics or in jb blue...here's a screenshot regardless.
I ran Nos for a day and couldn't stand it because the scrolling was glitchy and kinda slow in the internet...it might have just been the kernel though...whats the best kernel to run for that rom? My phone was really overheating too with palmer's kernel too..back to stock rom debloated I go
