antone31
Active member
Jellybeer is pretty bugfree..although I can't get wifi to turn on or work w it..I could I would be on it right now as it has a working camera for soap..if anybody knows how to fix the wifi let me know
From what I've read, Carbon and revolt are good roms. Anything by pio seems good.
With NOS I'm using the stock kernel. Still going smoothly.
The battery life on digital dream was pretty normal, about what I was getting stock.
I'm running Hatka supreme right now and battery life is a little bit better than stock, but I have noticed that my screen flickers on occasion when typing or navigating the screen. Not sure if this is a hardware fail or because of the Rom, but looks like I will have to deal with it either way.
Jennifer Stough
Forums Moderator
Device: Droid DNA unlocked, s-off, rooted, running Hatka Supreme Sense 5.0, Android 4.1.2
No issues with the camera or apps crashing on you?
Sent from my HTC6435LVW using Tapatalk 4 Beta
Nope. Camera and front facing cam works perfectly. No app crashes, no FC on any apps that I previously didn't have problems with (my banking app isn't fully compatible with JB lol). Only "flaws" are no zoes, and WiFi needs to be disabled and data enabled to receive and send mms. You will receive them, but they will not download. If you have both enabled, it will not switch automatically. Not a big deal though because I can switch to 4g when I want to send an mms or when I see that I have received one.
Jennifer Stough
Forums Moderator
That would be very annoying for me... I send and receive a lot of MMS all day for work matters (group text threads)
Im still running stock rooted with all bloatware removes and then some and I'm getting like almost 5 hours of on screen time. ..besides when I play candy crush haha...guess I'll stay on it til some of the aosp roms get updated
I went to Carbon next, and that is what I am using still. No app closings, good custom settings, and with a different kernel, the battery life is better than when I first flashed it.
Carbon is available at [ROM] CarbonROM HALO Linaro GCC 4.7/-O3 JB | Droid DNA > XDA
I'm running with the included kernel and have been pleased with it. I was also happy with Viper, but I was having a consistent issue with elevation readings in a GPS program I use, so I tried Carbon to see if the problem would go away, and it did. Each ROM has its advantages. Just a case of figuring out which one suits your taste.
Any bugs? MMS, camera, gps, force closes or resets?
Sent from my CM7 OG Droid using Tapatalk
I'm still in my first week of use with Carbon, but I'm not having any issues. I haven't tried MMS. I've taken a few pictures, and I prefer the Sense camera, but this is still usable. GPS was the issue for me with Viper, and I haven't had any issue with GPS use in Endomondo on Carbon. Riding 160 miles on Saturday, so that will be a big test for the GPS. Since it is CM based, any known CM issues could obviously exist in Carbon as well.
Damn :/ I had CM problems on PACman. Keep me updated because I really want to get away from Sense.
