My Samsung S6 is crackling when I put sound on at a high volume. How can I stop this?
A
AC Question
I accidentally dipped my phone in water but I had the case on. (Otter Box).
I don't know what to do.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Re: My Samsung S6 is crackling when I put sound on at a high volume.
Otterbox isn't a waterproof case. (You can probably drive over it, though - I wouldn't do without mine.) You probably damaged the speaker a bit. Either keep the volume off max or have the speaker replaced.
justinedwards
