My vibrate motor stopped working
thepurpleturtle
150
I think it's a software issue, but all the sudden the vibrate motor only works 1 in 50 times. Are there any apps known to do this or is anyone else experiencing this?
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Did this start happening after you installed an app, service or changed a setting?
Factory reset (backup before hand) and see if it works properly. If not, then it definitely sounds like a hardware problem, which is not unheard of, but doesn't happen very frequently.
Charlotte Rise FC
