Need Help with Battery-WiFi
this_is_nascar
780
Over the last couple months, battery life has shortened quite dramatically. I don't understand how to interpret these stats, however, why is WiFi showing this when I've had a mix of times when I had WiFi on and off?
Thanks.
Sent from my XT1254 using Tapatalk
this_is_nascar
780
Pretty please? I could really use some help here folks, in addition to learning how to find out what's keeping the phone awake, as shown above. I'd really appreciate the help and/or advice. I'm not rooted.
doogald
Trusted Member
Jan 3, 2010
4,425
55
In advanced wifi settings there is a setting scanning always available, which keeps the wifi radio on for location services even when you switch it off. Could be that?
Cell standby being high would be more worrying. There are times have bad signal.
Anyway, you're trending to go through a full day easily. That's pretty much all I need from my phone. I plug in while I sleep anyway.
this_is_nascar
780
Thanks. I appreciate it. What about all the awake time? Anyway to find out what that is, without being rooted?
doogald
Trusted Member
Jan 3, 2010
4,425
55
Force stop Google Play services? I don't think so...
Awake time are apps getting updates in the background. What are the two apps with icons in the status bar in your photos? One has the date, the other is a square with a bunch of stuff inside. Maybe it's one of those?
Do you have a weather app or widget that gets updated periodically? Facebook, Instagram, twitter? Do you have an email app that updates on a schedule? Any phone calls? That would explain the awake time (which doesn't look too bad in that graph.)
this_is_nascar
780
I gotcha. It's probably those background apps, as you mentioned. I get email and weather updates hourly.
