lance1955
Just go here and use shabby method it bullet proof and super easy once you have the drivers installed on your pc for the phone. [ACS] One Click Root Samsung Prevail/Replenish Shabbyfied - Android Forums
BY the way this works on new OVA update and does not wipe your data. Make sure to UNMOUNT THE sd card and remove it from the phone, usb debug on. Run the program with usb cable attached to phone hit enter on PC and bingo phone will reboot. If it gets stuck on samsung screen and is vibrating, just remove the battery, reboot and your have successful root, put the sd card back in and your good to go. I had to do it twice to get it to work.
