It stopped working awhile back. You will have to download a demo version of CDMA Workshop and then follow instructions on the first page of this post. You only need to run CDMA workshop once to get your msl, write it down somewhere (I put mine in a text document on my harddrive), and then you won't need CDMA workshop anymore.
Installed 01120 today, first non-stock PRL. No difference in signal quality apparent (2 bars), but does seem to hold onto a 3G signal a bit better. Next few days will tell.
So...what's the consensus on the BEST of the PRLs?
Tried the latest 01120, and experienced more 3G disconnects than usual and lower connection speeds. Reverted back to 60679, and 3G connection is good again. Might be the PRL, or might be just coincidence... sticking to what works for me.
For me it was, I get a bad signal at home and a high tws, with 60678 I get a little bit better reception and a way better tws, I'm sure results will vary
Sorry tws = ? I get really bad service on my road, so I'm trying to look into this :]. And what one should I download? Seems like theirs quite a few. Newest isn't always the best?
