problems with my ace plus
Jul 7, 2013
15
I have my galaxy ace plus s7500 works very well
I use pdanet for a month and every thing is fine .
2 days ago I plugged my device to my laptop and
nothing happens I made every possible attempts
to solve that problem but in vain. The thing that
drives me crazy is the phone isn't charging
neither on usb nor on the charger. A message
informs me that it is not recognized no longer
appears after restoring factory data pls help me
Im new to that nice site ....
Jul 7, 2013
15
check this: I plugged my charger I waited 5 minutes then I heard the charging beep then I used the usb cable and it worked. I do not know if this will work for forever as this happened with me once before.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,612
4,757
113
Welcome to Android Central! Please be patient--someone will try to help you soon.
Sent from my DROID RAZR using AC Forums mobile app
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,612
4,757
113
What you describe sounds like a hardware problem with the USB port, since you were having problems charging it using a wall charger. How old is your phone? Has it been dropped recently?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,612
4,757
113
USB cables can become faulty, so try a different USB cable (preferably one that is known to work with your phone).
Also, try rebooting your phone if you haven't recently (i.e., power it off completely, then power it back on).
TSFDeymos
