pags11
I preordered the 2 pack of the Whitestone Dome glass screen protector largely because they had a 40% off coupon and I figured having the backup would be nice so over time as it gets worn a bit I can swap it. This is my 3rd dome screen protector and I've gotten pretty comfortable with the install. However that being said this has been quite a trainwreck and I've been reaching out to Whitestone for a couple of days and they just will not respond.
The first issue is that the instructions are a bit of a mess, there is the instructions as well as an supplement that Contains step one, then skips to step 5. Also the kit now includes masking stickers to cover the buttons / ports to prevent the adhesive from getting where it shouldnt. That being said, the written instructions say to put it on all 4 edges, and then there are 2 pictures, one showing all 4 and one showing 3 sides. The problem is that the two pack only has 4 masking stickers.
Being that the cage used for the phone had changed a bit I read through the instructions and watched the video guide.
The first install I thought went pretty well until it was cured and there were quite a few bubbles, So i took the glass off and it came off clean, so I cleaned everything with alcohol and tried again. Then I did it again, this time the adhesive didnt make it all the way to the top, it had a slight lip around the top that didnt get adhesive. So I tried taking it off again, this time the glass cracked. OK, glad i bought the two pack, and tried it again with the second glass. This one had the same exact issue but an even larger gap at the top.
It feels like they either underestimated the amount required for this phone adhesive wise, or they were having complaints of having to clean up all the adhesive with the alcohol wipes so they've reduced the volume they include. Either way it just doesn't seem that the install is working like it has in the past.
That being said I've reached out to them using their contact us page, as well as reaching out via Twitter. They never responded via the contact us page, but their twitter asked me to DM them and they would assist me. Two days later they have yet to reply to me there either. I am at the point where I am just going to do a credit card charge back but I cant believe the lack of QC or customer service for them considering they've always made a great product in my experience in the past.
Any suggestions on another screen protector would be great
I compared the bottles of loca glue that were in the Whitestone Dome kit for my S20 Ultra with the ones that came for my S10+ previously. They are the exact same size. So, to your point, it may be smart for them to increase the amount of glue in each bottle. Also, after putting my screen protector on, I think the circle on the plastic piece that lays down on the protector during the installation needs to be put up higher. I had to wait 5 minutes before using the UV curing light to wait for all of the glue to get to the top. I still think Whitestone is the way to go, just some things they need to adjust for the S20 Ultra installation process.
