[RECOVERY] CWMT Recovery 5.0.2.7-th7 (T is for TOUCH!) OV
Should we have official CWMT Recovery suppport?
  • Total voters
00_wrath_00
657
82
I have updated the OP to state that this recovery should not be used with LeslieAnns radio update zip. I appologize for not updating it sooner. I am without a pc and no longer using VM and barely use my OV. Planning on ebaying my OV but will try to keep this recovery up to date untill drew starts an official OV thread.
Sent from my VM670 using Tapatalk 2 Beta-4
sblood86
426
103
looks like this recovery not support link2sd nandroid backup either. am i right?
Not sure. There's a link in the OP for the OS forum I'm sure the info your looking for is there.
It's CWM v5.0.2.7 with a few modifications (primarily making it run on the Optimus S {and subsequently V}, and the adding of touch controls {there are some other things but I'm too lazy to list them}).
Point is if CWM v5.0.2.7 supports link2sd nandroid then yes; if not, then no.
Edit: I haven't checked myself but assuming it doesn't, do you know a recovery that does? I'm sure Drew or myself could look into merging such functionality.
00_wrath_00
657
82
Perhaps more important would be to discover why this version of CWM cannot flash radio images.
In the OP I copied from the OS forum it states radio flashing was disabled. Maybe that's why it bricks when flashing radio. If it sounds like I'm being a jerk I apologize lol.
00_wrath_00
657
82
is there perhaps a version with radio flashing enabled?... :)
good question. I'll look over on the OS forum and see if an older version has radio flashing and report back.
Edit duhhh me long night lol all I had to do is look at this OP since its copied from the OS thread lol.
samlin168us
Active member
May 2, 2011
34
4
I only tried VM670NH_recovery.img. It works fine.. When I switched to touch, and bricked my sd-ext.. I am noob. :)
sblood86
426
103
So I'm pretty sure that's Bob's recovery (someone correct me if I'm wrong), that should just be CWM based recovery same as the recovery found here; only difference is going to be the kernel I expect and possibly version. Anyway, point is I expect there are much differences, certainly nothing that should effect backup/restoring to sd-ext. Most if not all of the backup functionality is handled by platforms/bootable/recovery/nandroid.c which as you can tell from the commit log Drew has only made one change to this and I can't imagine how it would effect the sd-ext backup (at least not in a way that would cause it to fail to restore), I could of course be wrong.
Someone wanna check the version number in Bob's recovery that way I might be able to get a better idea of possible changes made to nandroid.c
In regards to the disabling flashing of the radio; it was to my understanding that flashing a radio image could cause serious issues (when using custom recovery); having said that if someone has successfully flashed a radio image from a non-stock (fully open source) recovery I would love to know about it, as this is something I was considering looking into anyway (Xionia does this to an extent if I recall but it's also a much older recovery version).
Edit:
That should have of course been "aren't" but I think you all got my meaning :D
ThatGuyLurkin
2,155
665
Alright I give in. Here's a freshly compiled build of Cannibal Open Touch v1.0.6 for the LG Optimus V.
http://www.teamhydro.net/downloads/Recovery/Cannibal-Open-Touch-v1.0.6_thunderc_vm.img
It's untested as I don't have an Optimus V but should work fine. Don't flash unless you are prepared for a potential brick.
So many updates I can't keep tracking.
One time I got am error. What does it mean?
drewwalton19216801
2,476
2,803
The page just shows a bunch of symbols wont let me download
Known issue, nothing I can do about it right now. For now, use a REAL web browser on your computer.
Click to view quoted image
It means exactly what it says; you ran out of memory. Reflash it until the error goes away.
Reactions: ThatGuyLurkin
Summer_glow
