Thanks man, wow kind of hard to choose. For circle based I think number 5 looks nice and simple.
Looks like there is a
really cool app that will let you pick your own battery mod and install it! It has the battery meter #5 on there, I just flashed it and it works great. The only catch is it will change your notification bar back to stock (grayish fading color). If you don't care about the notification bar flash away. If you do, I'll work on making some battery mods with a black notification bar, but this takes some work (feel free to grab that batter meter in the meantime if you like, since you can always reflash the Mini Theme to change back).
ragnarokx you did an awesome job with the reboot of this rom i love it
keep up the good work
I thought the BIOS boot up was a nice touch, glad you like it
Alright, so the only issues that I have found so far are:
1. Wi-Fi doesn't connect. It cycles through Scanning-Connecting-Disconnected repeatedly (I am trying to connect to a hidden SSID, but that shouldn't matter)
2. Cannot set custom ringtones to Sounds (causes a crash)
No complaints though, just trying to be helpful with bugs. I'm not really worried about either.
Keep up the good work, this is my favorite ROM so far.
I'm going to post a couple zips for you to flash and see if we can resolve those problems. Should be up later tonight, or tomorrow at the latest.
Yep this is an awesome rom, kudos to ragnarokx. The only issue i've had is launcherpro will take an extremely long time to load after bootup and sometimes goes on the brink of crashing where it consumes 60mb of ram when normally it's around 18. If i terminate it it reloads fine again lol. Still an awesome rom though and can't wait for a battery meter with percentage.
Honestly I've only used the AMLauncher and this is the first I'm hearing of problems with another launcher. Is this happening only after booting up, or does it happen all the time? And take a look above regarding the battery meter.
You rock, Ragna. Thanks a lot. I'm a little OCD so this bothered me more than it should have lol. This ROM is great by the way. Can't wait for froyo custom kernels so I can ditch juicedefender.
Sent from my SPH-D700 using Tapatalk
No problem, weird things bug me too so you're not alone. Thanks for the compliment, and I can't wait for custom kernels either!
When I'm in clockworks (orange text) nothing works - Everything command I run it says "unknown volume..." "can't mount..." "can't open"...
EDIT: I failed to follow the cardinal rule ALWAYS FOLLOW IMPORTANT NOTES!!! jebus... it even told me I cant use ROM Manager to reboot into CW3....
So are you ok, got it figured out?
