does this give any more free space compared to hydro's cm10?
Yup
Just have an ext partition
Sent from my LG-LS670 using Tapatalk 2
@jonny5449
Can you add versions to your updates. Possibly update the title for the OP. It makes it easier to know when there is an update. Thanks.
Sent from my LG-LS670 using Android Central Forums
Question.. Does the microphone work? I've been using drew's CM10 for a while and my only complaint was the microphone not working (in call or Market's Voice Search). Either way, totally flashing this once the download is finished.
I love it so far. Glad you ported Zakman's CM10 over You've got yourself a groupie for your Optimus S CM10 :3
has anyone even tested this yet? Click to view quoted image
It works pretty well, It still has the same bugs that Zakman's CM10 for Optimus V has. Also not sure if calling is affected as I don't have working cellular service on my phone (not enough money to start a sprint account) but the microphone doesn't work at all. Voice Search, Voice Dial, etc don't work. Also, migrated my sd-ext from Drew's CM10 and if you are able to get Google Now working, it's awesome :3 The only problem is that it doesn't scroll the results or cards.
Any suggestions on how to fix Google now??
I'm not quite sure how I got it to work. Been trying to get it on my Android-x86 netbook running 4.0.4 and nothing seems to work. I've just been using the installed version on my sd-ext that magically started to work :?
Hmmmmm that's strange ext for computer or android
