[Rom][WIP][ZVD] Slimmed CM10 Alpha 6
Status
Not open for further replies.
Shinkenred
322
19
18
jonny said:
ok download a root explorer
...wait, what the deuce!? You mean The ROM doesn't already have Root Explorer or File Explorer built-in like most!? That's odd...
Sent from a Purple LG-LS670 with CM9...the New Wolzard Phone...yes.
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
I know lol I got permission from jrummy to include his in next build will have sorry but trust me its worth
Sent from my LG-LS670 using Tapatalk 2
nitestalkr
889
261
Re: [Rom][PORT OF A PORT][ZVD] CM10 Jellybean
@Zackman, instructions are included in the zip, this is NOT flashable(however, I will include this in all of my patches I made, by Saturday.), and this is to be implemented into the ROM.
app2ex-fix.zip
If you want, you can implement this into your build, just follow the directions in the zip.
They must be added into the ROM.zip PRIOR to flashing, and is NOT flashable!!!
This will do exactly what tdm's Quattrimus will do, automagically move all apps to the sd-ext partition.
And the following is my recommended way of creating the sd-ext partition.
A very simple 4 step procedure that I use with Minitool Partition Wizard:
1.) Connect your Optimus to your computer and mount the SD card.
2.) Open Minitool Partition Wizard, resize the SD card, leave 512mb or 1-2gb of free space.
3.) Create a new ext4 partition with the free space, mark it as primary, apply changes.
4.) Disconnect your Optimus and reboot it.
The procedure above does NOT wipe out your SD Card, unlike the Recovery method.
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
I'm asking for permission for both apex and nova to be included
Which one would you guys like included
I say nova because its really smooth and better than the launcher currently
ThatGuyLurkin
2,155
665
he said it wasn't working in the rom...i thought it could be worth a try to include that version....:p lol
I forgot this was Jelly Bean o_o
It isn't fully functional, and it breaks Google Search.
sent from my Zom-"Bean'(CM10 JellyBean).
That's why I said I don't think so I wonder what the problem is
So it works just no Google Search?
harsho1
Active member
Mar 28, 2011
32
I have always preferred Zeam launcher because of its small size and still plenty customizable.
Status
