I had problems before MM update with trusted places, so figured I'd re-test and sadly it still doesn't work. Phone continues to remain locked even when I'm at a trusted place.
So I attempted to start from scratch after MM update: From Settings->Lock screen & security -> Secure Lock settings -> Smart Lock -> Trusted Places, I've gone in and disabled HOME and removed all other addresses. So there's nothing turned on.
Restart phone and am surprised to see 2 addresses enabled again even though I just deleted or disabled them. The 2 addresses that are active again are HOME and an address from my saved addresses.
So there are really 2 problems here: trusted places doesn't work AND I can't seem to remove the addresses.
My Location method is set to "High accuracy" and I'm using screen lock type = "pattern".
Any ideas ?
thanks,
chris
Any ideas ?
thanks,
chris
