Unlocking and Rooting the HTC One - AT&T, Dev, Unlocked and International model
Dave Menday
Hi all,
I have unlocked my bootloader and i have used clockwork mod on it ad successfully loaded a custom rom but i tried to sideload another rom using Hasoon2000's HTC tool Kit and now i can't get the phone back to recovery mode even after flashing the clockwork mod again. It just says entering recovery mode seems to start then turns off.
Any advice would be great. Have i just made a paperweight.
wizzrah
Retired Ambassador
Jul 27, 2013
4,686
Hi all,
You can try flashing TWRP recovery. See if you can boot into recovery then.
Sent from my One Xl using Tapatalk
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
Hi all,
Is the bootloader still unlocked ?
Dave Menday
All ok now just for the record I had to format the sdcard etc (internal) and then remount. The do a side load everything is now working great with Venom one rom.
p.s thanks for the help
jondon156
49
Hey wizzrah do you have any ideas on how to get my htc one back into recovery. benny3 suggested it may have a corrupted EMMC.
Our discussion is here: http://forums.androidcentral.com/ht...k-bootloader-cant-get-into-recovery-help.html
I found a thread discussing how to possibly fix the corruption but I need to get into recovery.
Android Revolution HD | Mobile Device Technologies: How to: fix a corrupted DATA partition on the HTC One
I've tried re flashing recovery. I've tried locking bootloader and flashing using RUU, but the bootloader won't lock. I'm locked how of everything except bootlaoder/fastboot usb. If I try anything such as enter recovery or reboot I get stuck in boot loop.
wizzrah
Retired Ambassador
Jul 27, 2013
4,686
Do you still have the unlock code for your bootloader?
jondon156
49
Fastboot flash unlocktoken unlock_code.bin
ok I did it and it failed. here is the output
c:\Users\bricedorman\Desktop\platform-tools>fastboot flash unlocktoken Unlock_code.bin
target reported max download size of 1526722560 bytes
sending 'unlocktoken' (0 KB)...
OKAY [ 0.140s]
writing 'unlocktoken'...
FAILED (remote: unlock token check failed)
finished. total time: 0.140s
Clifford Ball
The link supplied above for the [TOOL] HTC One (M7) All-In-One Toolkit V1.2 [4-11-2013] [PERM ROOT][Noob-Proof] - xda-developers has been removed on the XDA site. Does anyone know where I can get a copy? My HTC One (AT&T) locks up when I boot my phone in recovery mode and never get to the screen to install zip from sdcard. I'm hoping this toolkit will help me finish the rooting process. I've done everything else up to this point, but can't go any further. Thank you
MrCGym
Active member
Apr 29, 2013
39
This is something i am looking to do on my AT&T HTC One. Any suggestions on ROMs? Approximately how long does it all take?
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
I opted to gain SOFF and flash the GPE's complete firmware, effectively converting my device to a GPE. It was great.
MrCGym
Active member
Apr 29, 2013
39
Yeah, I'm completely new. I just learned on youTube how to root. Apparently I first have to unlock the bootloader. What is SOFF and GPE? Sorry for the newness here.
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
GPE = Google Play Edition; it's the version of the One that you can buy direct from the Google Play Store, and it uses stock Android software as opposed to HTC's Sense software.
S-OFF is a weird thing. HTC handles their firmware/software a bit differently; when you get the device (stock) it's shipped S-ON, meaning that you cannot "write" to a certain partition of the software (the NAND, if I recall correctly). In order to gain full control over the device, not only must you unlock and root the device, but you must achieve S-OFF so you can "write" to that partition. For example (IIRC), one cannot change the bootloader ("HBOOT") on an HTC device, in particular the One, without achieving S-OFF. In the ye old days of HTC, the only way to achieve S-OFF for some devices was to physically change something, I believe it was a matter of touching a wire to something else (I didn't have one of these devices, so pardon my ignorance). With the One, you can achieve S-OFF through certain pieces of software and loopholes. When I achieved S-OFF, it required a variety of different steps because an AT&T update closed the previous loophole. Now, I believe the process is much simpler and has been reduced to piece of software, but you may want to read up as I sold my device months ago.
I needed S-OFF for two things: to reset any sort of "tampered" flags from unlocking the bootloader and to be able to install the complete GPE firmware, including the GPE HBOOT/bootloader. Otherwise, you can flash (install) a GPE ROM. The benefits of a full conversion is that all of the software is stock and it is updated very quickly through Google/HTC, as opposed to being at the mercy of the carrier. I also had to change the CID (cell ID, if I recall correctly) so the GPE firmware/software would properly install.
While hacking the One is a lot more straightforward than most devices, it's not even close to Nexus devices. I recommend reading up on it a bit, watching YouTube videos, and asking questions if you are unclear.
Good luck.
silverpalm
hello guys and gals
i have a htc one m8 on ee,i was looking to s-off so i can sim unlock,can i use the uxtoolkit HTC One M8 AT&T to do so then the method to pem unlock
im not to bothered about a custom rom maybe in the future
or is there no way to s-off a one m8 on ee as i saw a thread about it the person who started it never update to say if it worked
thank you for any help
wizzrah
Retired Ambassador
Jul 27, 2013
4,686
hello guys and gals
You might want to post in the M8 section. This is for the HTC One M7.
