Verizon Fascinate: Froyo EB01 FAQ Plus Stock Unrooted and Rooted Downloads
masterlange
Active member
Dec 8, 2010
34
thanks for your patience! I reinstalled everything, followed the steps on your link and it finally worked. Now do I have to do anything with that sd card update.zip?
DroidXcon
11,102
3,392
Landshark
4,434
1,382
113
Can I use a file manager like ASTRO to back up my apps? And if I reinstall it after I flash EB01, will it bring them back from the SD card?
You would typically use Astro, Root Explorer, or similar file management app to move files around on your phone. As far as I know, they are not designed to back up your apps. Apps like Titanium Backup and MyBackup are designed to backup your apps. If what you are asking is if you can use Astro or Root Explorer to move the apps to the sd card then move them back after flashing EB01, I suppose you could. But that would take forever. Makes much more sense to use TiBu or MyBackup.
