Will the leaked 4.2.2 leaked firmware work on ATT?
tmp3150
Banned
Apr 1, 2013
110
HI,
I didn't see this posted anywhere, but I was wondering if the Samsung S4 leaked firmware work on the ATT Samsung 3? Its marked a i9300xx, so does that mean its international only?
Thanks!!
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
HI,
Thanks!!
I believe so. Rule of thumb for flashing is, if it doesn't match your model number, leave it alone. I am sure they are testing builds for 4.2.2. Soon, that version will be in the States.
Scythe55
70
If all you want is 4.2.2, put cyanogenmod 10.1 on your S3. If you want 4.2.2 that looks like the S4, slap the CM10.1 S4 theme (available in the play store) on the phone.
Whatever you do, as Golfdriver97 stated, is never flash a ROM unless it is specifically for your phone - otherwise you will likely brick it.
Mrjhe29
