No Service problem on Fascinate
sloppyart
Active member
Nov 3, 2010
25
Several weeks ago I rooted my Fascinate without any issues.
It has been running fine until recently when I started getting the no service icon where the bars normally would appear.
I am in an area with very good service, so I don't think that is the issue.
I have restarted the phone, removed the battery, etc. This hasn't helped.
I have not had a chance to experiment with moving to a new cell area, so it is possible that they may be doing work in the area, but this is happening fairly often now, so I'm starting to think it may be the phone.
Could the rooting of the phone cause this, or is it more likely a bad phone.
I'm thinking the best option is to unroot the phone and bring it back to stock so I can return it at the Verizon store, unless someone has another suggestion.
Thanks.
DroidXcon
11,102
3,392
No rooting would not cause this....what modifications did you make after you rooted
Thanks.
Sent from my SCH-I500 using Tapatalk
Reactions: sloppyart
sloppyart
Active member
Nov 3, 2010
25
No mods, that I know of.
The only apps that I've added that require rooting are:
BlackList
Super User
I'm thinking this is a phone issue, but just wanted to make sure.
DroidXcon
11,102
3,392
Baseband: S:i500.04 V.DI01
Build: SCH-I500.DI01
Thanks for the help.
Try doing the over the air update to EA28 you can always reroot later.... this will give you a new radio on your phone and maybe able to correct your reception problem.......as long you didnt remove or change any stock apps you should be able to update with any problems
DroidXcon
11,102
3,392
Put this on the sd card,,,not in any folders
http://adrynalyne.us/files/patches/DI01_to_DL09.zip
rename it to update
then shut off your phone
hold down volume up+down+power
samsung will flash twice , after the second time let go
this will take you into recovery
then scroll down to apply sdcard:update.zip hit the home button to select
this is the official signed update and will update your phone
sloppyart
Active member
Nov 3, 2010
25
I got that to load. I can select the file by moving the highlighted text with the volume.
How do I select that? I pushed the power button, that doesn't seem to do anything.
Thanks again. This has been very helpful.
smokedog87
