Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Like Tree1Likes
    Default wth is going on with my nexus - charging problems
    theres something wrong with my nexus right now. i cant tell if it is charging or not.. the battery icon the notif bar shows that its charging but sometimes t he lockscreen wont notice it as charging. and even though it shows that its charging my battery is still dropping im not even pushing it either its at zero brightness and im barely using the screen.. someone please help
  2. #2
    tdawg00's Avatar
    Posts
    Global Posts
    168 Global Posts
    Default Re: wth is going on with my nexus
    Check under settings> battery and see if it says "Not charging"
    it says charging(ac)
    a couple minutes later it says not charging.. but the top battery icon is showing that its charging and it is plugged in.
  5. #5
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    There might be a problem with the usb port. If it persists, and you can replicate it, i would take it into verizon for a replacement unit.
    If you dont want to do that, you might want to try a factory reset but that will erase everything on your phone and the sd-card memory, and i dunno how likely it is to help but it might be worth a shot.
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
  6. #6
    cj100570's Avatar
    Spoken Word™
    Posts
    Global Posts
    409 Global Posts
    ROM
    Jelly Bean
    The battery icon in the status bar always shows the lightening bolt when the phone is plugged in. "Even if it's fully charged!"
    It is better to be pissed off than to be pissed on!
  7. #7
    The first thing I would do is pull the battery (while the phone is still on). Leave it out for a minute or so, put it back in and see if goes back to normal. Sometimes these mini computers need a hard reboot.
    Semper Fi
    I love my LG Nexus 4!
  8. #8
    Default
    I've had the same issue and couldn't get it to go away. Had to swap phones.
  9. #9
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by cj100570 View Post
    Same here. Even on replacements and others I've seen, which presumably means the icon is always like that if charging.
  10. Thread Author  Thread Author    #10
    i guess my charging cord was faulty bc i got a new one and the problem went away it seemed like the phone knew it was plugged in but wasnt charging
  11. #11
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    Quote Originally Posted by incrediblenotinstock View Post
    The lightning? Weird. It did it with the customer service model as well so I presumed the icon just indicates it's plugged in.
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk
  12. #12
    pauliphone5's Avatar
    Posts
    Global Posts
    2,563 Global Posts
    ROM
    ICS 4.0.4
    Quote Originally Posted by dmmarck View Post
    Its how ICS is set up I think. The Xoom shows the same thing when it is charging too.
  13. #13
    I had this problem with my GN and it ended up being the ac adapter for the usb cord went bad.
    Thanked by:
    Johnly
  14. #14
    Johnly's Avatar
    Posts
    ROM
    AOSP, & stock.
    Quote Originally Posted by Hand_O_Death View Post
    This makes sense...
  15. #15
    Posts
    Global Posts
    2,563 Global Posts
    ROM
    ICS 4.0.4
    Default
    I get it no matter what USB cord and plug I use. I also get it with the car charger. It is like that on both the Xoom and Nexus.
    Sent from my iPad using Tapatalk HD
  16. #16
    broadwayblues's Avatar
    Posts
    Global Posts
    493 Global Posts
    ROM
    Stock Rooted, Unlocked
    Default Re: wth is going on with my nexus - charging problems
    Is it me or is the GNex very sensitive to charging cords? It really is picky and if I don't use my factory cord, there is always a chance that it won't charge.
  17. #17
    Posts
    Global Posts
    2,563 Global Posts
    ROM
    ICS 4.0.4
    Default
    Quote Originally Posted by broadwayblues View Post
    The only time I have had a problem with the charging is when I used a rapid charger car charger on it.
  18. #18
    cckgz4's Avatar
    Posts
    Global Posts
    2,124 Global Posts
    ROM
    MIUI
    Samsung chargers seem to be faulty
  19. #19
    mds54's Avatar
    Posts
    ROM
    Stock
    Mine suddenly stopped charging when I'm using the phone while plugged in. It still seems to charge when idle.
  20. #20
    Posts
    Global Posts
    2,563 Global Posts
    ROM
    ICS 4.0.4
    Default
    Quote Originally Posted by mds54 View Post
    That isn't anything new for some phones. I think that is by design.
  21. #21
    MikeOM's Avatar
    Posts
    Global Posts
    43 Global Posts
    Default
    The only charging problem I have had is sometimes the phone just does not start charging when plugged in. A reboot fixes it though.
  22. #22
    dlcullen's Avatar
    Posts
    ROM
    CM7 92611Ntly / CM 7.0.3
    I've had problems with mine charging, it wouldn't charge with the cord that came with it so Verizon replaced it with one of their generic charging cords. It doesn't seem to always want to charge with that one either, it always charges with a couple of my old BB cords.
    They have finally come out with a stock charger ETC-CPK008GSTA these are nice and will work with either the stock or extended battery. Amazon has them for $33
  23. #23
    I am having the same issue. After 3 phones and hours of retelling my situation to Verizon technical support, I finally got the answer. The phone will charge when it is off with any universal charger.....however.....in order for the phone to charge while it is on, you need the specific charger made for that phone. Ive never had this issue before (and ive had many phones) but its true! Hope this helps
  24. #24
    Quote Originally Posted by stephstaff77 View Post
    Don't think this is correct. I charge mine on different chargers (home and car) and it's always on. Never had problem with it charging.
    I think I do notice that it charges much faster with the oem samsung charger.
  25. #25
    Default
    I had the same problem with my e4gt. 1st time I had to swap chords 2nd time I turned off the GPS and it charged in nothing flat.
    Sent from my SPH-D710 using Tapatalk 2
