Widgets not updating on 4.0.4 info??
tobrizonwireless
Active member
Oct 14, 2010
25
Sorry if this has been answered already but after the 4.0.4 update some of my widgets (Beautiful widgets, battery widget etc) have stopped updating from time to time and didn't know why it's doing that.....is it because of the update? Will it ever be fixed with another update?
Mr.Gadget
319
8
I bought "HD Widgets" that no longer works. When I place a widget, even on a blank screen, it says there is no more room for the widget. This is on two separate GNEX phones... Bummer. I bet it is a widget programming thing, as in, they won't work until they debug the widget (as opposed to Google "fixing" ICS)...
cj100570
Spoken Word?
Nov 12, 2009
417
24
I'm having the same issue with Beautiful Widgets, the time stops updating from time to time. I'm also having the issue with the Music widget, it'll display a song and then won't update to the next songs that are playing. A reboot or force stop of the app is the only cure I've found.
tress
