A
AC Question
How do fix the mount script error
I have recently bought a micromax canvas spark(Q 380). It has got 1GB ram and 8GB internal storage with a lollipop 5.0 android version. When I tried to move installed apps to SD card it can't be done. Then I searched for the solution I got to know about the "link2SD" app which helps move the apps to SD card.
The process goes like this :
1. Make a partition of the SD card through the mini partition tool.
2. We allocate some space for apps and the remaining for the media files.
3. We then have to mount the newly created space of the SD card through the link 2 SD app.
This is where I can't proceed from. It says (Mount script error. Mount script can't be created..not allowed to su..). Help me out..
