I have an AVIC-F70DAB installed in my car; that's the equivalent of the NEX7100 I believe with built in sat nav.
I have been having some frustrations with voice commands.
Randomly it will say "If you are speaking I can't hear you" (or words to that effect) when I press the mic button.
It can sometimes be fixed by unplugging the phone or turning off the unit and other times it can't. It seems to do it for no reason either; it will be working fine then stop.
I've seen similar behaviour with Siri in CarPlay; it won't hear anything. The thing is it isn't the mic as I can make a phone call and I come through loud and clear.
Anyone else experienced this? Thanks.
