Re: Why doesn't Android Auto Connect with Bluetooth
Pretty sure your roku isn't using Bluetooth to stream video. Its probably using Wi-Fi or Wi-Fi direct. Bluetooth is very low bandwidth. 24mbps with Bluetooth 4 and that's theoretical max. Real world will be slower. Wi-Fi direct hits 250mbps (or more?). But I think a bigger reason is compatibility and battery. Sending all that data (music, system info and real time video) wirelessly would drain the battery relatively fast. And a wireless video connection is more expensive and difficult to implement versus regular old video over a cable (remember, what you see on the screen in your car is rendered on your phone and sent via video out to the screen. The system is essentially just a fancy monitor for AA)
And I do agree with the above post. As someone who has a premium audio system in his car, Bluetooth audio quality just plain old sucks. As in truly stinks. I want it via cable on Android auto. Failing that, I'll use the aux jack before I ever touch Bluetooth..
