Hi,
Previously, I was listening to my music (and Maps voice navigation) over Bluetooth, but finally decided to try using AA. Everything works fine, except the volume seems to be too loud. On my Honda, I used to use a volume of around 13 to 16 when using Bluetooth, depending on the music and my mood. This was with the volume at "safe max" (before the phone warns you about things might be too loud) on the BT volume settings on my phone.
Now, using AA, I can only set my car's volume up to about 8 or 9. I've noticed that if I check my phone, the Media volume is always set to MAX when using AA. It reverts to whatever the previous setting was after I stop using AA. The problem with this is that 8 or 9 steps of volume isn't enough. It seems like if I raise the volume, it gets just a bit too loud, and if I lower it, it's a tad too soft.
Is there any way to make AA not set the volume to max? I have no idea if this is a phone/app problem, or something on the car. I would imaging it's related to my phone and not the car, but I don't know enough about how AA works. Any help would be greatly appreciated.
Thanks!
Warner
Thanks!
Warner
