Dear Sir,
I bought two android tv box, the model are pendoo x10 and Turewell t9, both are not able to connect to my network.
Thats beginning make me crazy. I want buy a android tv box with no network connections issues. Able to download apli. from the google play store , plex apli., amazon prime video apli. , netflix etc..
Unless you have a solution to fix my issues. You are so kind if you can please suggest me a tv android box.
Also I did attached two pictures The first one is the setup of my router
The second one is my tv box setup . My question is why the ip adress and the mac adress is different then my router ?
I dont know if i can change those adress in the tv BOX
