A
AC Question
Also, if the gmail accounts have had their passwords changed, and the device that wants to be wiped has the old passwords, will this prevent the Remote Wipe from working?
Finally, can the battery be removed, and the phone be semi booted with a USB connection to avoid the phone from reaching out to the cellular provider and stopping the wipe command from getting executed
thanks
thanks
