A AC Question Jul 8, 2016 #1 When my screen is off and you double tap to turn the phone on it does not work
Javier P Ambassador Feb 21, 2014 19,480 3 0 Visit site Jul 8, 2016 #2 Welcome to the forums. What device do you have? Is it an LG device? If so, go to settings - display - screen lock and make sure the settings for Knock Code are checked and correct. Upvote 0 Downvote
